In the audio of the VCI400 is Headphones the only option. Can i use external mixer.
geposted Mon 21 Oct 13 @ 12:21 am
Yes, that's right, the vci 400 uses the virtual dj software mixer and just gives you control over it with the faders and controls. So in the sound setup section of the virtual dj config, you should select the 'headphones' option.
There is an option to plug in external devices (ipods, mics, CD players etc) into channels 1 and 4 of the device and mix those with the vci's built in mixer functionality, but you can't route virtual dj to use the vestax mixer section, if that makes sense?
Hope that helps.
Hope that helps.
geposted Mon 21 Oct 13 @ 7:38 am
Yes, in VDJ sound settings, you need to choose 'Speaker + Headphones' as the output.
Not 'External Mixer' - because the VCI 400 does not have 2 separate outputs (only one master) - and cant be used in this mode.
geposted Mon 21 Oct 13 @ 7:59 am
As much as i love this thing im going to have to sell it, cause im missing my 1200s something awful...wiki/....wiki...
geposted Mon 21 Oct 13 @ 1:19 pm
Couldnt you start using timecode?
geposted Mon 21 Oct 13 @ 1:41 pm
dont think thats possible
geposted Wed 23 Oct 13 @ 6:41 pm
