Topic: Needing some advice, countdown video on external screen
My setup is a djm 400 mixer plus 2 cdj 2000 and a trakor kontrol x1. What i am asking is i am going to be having a new years party this year in my own flat and what i was wanting to do is have this playing http://www.youtube.com/watch?v=FbxYDC_Xf2c&list=PLv7F2HHSuYtIgqNXYEsF9ciICzfl5EuUe what should i do should i just burn the video to dvd and play it on my tv and play the audio in vdj. Any advice would be helpful ?
geposted Tue 22 Oct 13 @ 1:36 pm
You're a PRO User.
VDJ can play videos in different formats than any other dj software in the market.
All you need to do is get a copy of that video and configure your video settings (you might need appropriate cables - VGA, HDMI, Composite).
I am sure there's instructions on the support/help tab if you will dig into it.
https://virtualdj.com/wiki/Video_General.html
ok thanks will read but don't i need a mixer that can be used for djing video ?
Since VDJ supports video mixing, any mixer that works with VDJ will also 'automagically' support video mixing.
You dont need a special mixer for this - your current controller will mix video just fine with VirtualDJ
Hi Jag, I do visuals for free for the guys on the forums that are used in clipbank and make countdown vids each year for new years eve, again free of charge.
Check out.... http://visualshed.forumotion.co.uk/ you have to sign in to see the visuals, if you don't see what you like give me a shout and I'll see what I can do for you.
update i have now moved into my own flat my tv is quite far away from my dj booth is there a way to stream it to my tv cause im not sure i could get a cable long enough to reach iits about 4-5 feet away
I'd take a cable over wireless video any day of the week - especially for a tiny distance like 4 feet!
got this setup now followed the guide but only thing is when i want 2 display the video i get what is display on pc screen on tv. How do i fix it ?
Tayla!!! you rock!
groovindj thanks will give that ago im on windows 8 but looks just about the same
