hello. does the virtual dj software works with a10 sound card from native to run a timecode system. :-)
regards.
regards.
geposted Wed 30 Oct 13 @ 2:48 pm
Yes, if the A10 specifications say it will work on whatever type of computer & OS you have, then there's no reason it won't work in VDJ.
VDJ works with audio interfaces via the operating system, so if the A10 is compatible with your computer then there's no problem.
geposted Wed 30 Oct 13 @ 3:02 pm
But you can't use the TC Vinyls/CDs from Native because as far as i know they changed their signal a while ago so it is no longer supported.
You should pick some Noisemap TC Vinyls (like Serato uses, too).
Greets, Heiko
Greets, Heiko
geposted Thu 31 Oct 13 @ 12:12 am
hello.
thank you for reply.
the sound card is at the moment used for tractor but i don't like that program. i prefer vdj.
i vas thinking to use the vdj time code from the download area here on the site.
geposted Thu 31 Oct 13 @ 12:28 pm
