Gemini si rinnova nel mercato dei controller e ci presenta una coppia di nuovi prodotti chiamati G2V e G4V, console rispettivamente pensate per pilotare 2 e 4 deck con VirtualDJ.
Gemini G4V
USB/MIDI software controller with built-in professional 24-bit PC/MAC audio interface
4-channel mixer with 3-band EQ, Gain, and Filter control on each channel
Pre-mapped FX controls for Virtual DJ
8 multi-function pads and 4 rotary controls per deck
Includes quick keys for Hot Cues, Auto-Loop, Sampler, and Manual Loop
Touch-sensitive jog wheels
Responsive controls with high-resolution 14-bit MIDI
Midi mapping functionality over the entire controller
Front 1/4” microphone input with Gain control
Auxiliary RCA line input
Balanced XLR & RCA master outputs, RCA booth output with dedicated volume control, and front 1/4” headphone output
http://geminisound.com/product/g4v
Gemini G2V
2-channel mixer with 3-band EQ, Gain, and Filter control on each channel
http://geminisound.com/product/g2v
Gemini G4V
Gemini G2V
Recensione G2V: https://www.digitaljockey.it/dij/index.php?option=com_content&view=article&id=786%3Agemini-g2v-recensione&catid=101%3Ahardware&Itemid=56&lang=it
geposted Fri 01 Nov 13 @ 4:19 am
