when i use the mouse to move the crossfader to the left below 100% deck 1 starts playing and if the crossfader is at 100% deck 1 stops playing
geposted Fri 01 Nov 13 @ 1:16 pm
your fader start works
Map a key with "deck 1 fader_start & deck 2 fader_start"
juan
juan
geposted Fri 01 Nov 13 @ 4:02 pm
did you sort the problem?
geposted Sat 02 Nov 13 @ 8:58 am
been busy.
that command just toggles the deck playing when the crossfader isn't pushed all the way to one deck, idk if its supposed to act as a auto play trigger
geposted Thu 07 Nov 13 @ 4:32 pm
flux056 wrote :
been busy.
It makes it so that when you move the crossfader to the left or right the corresponding deck will start playing as you fade over. Nice feature for people who don't beatmatch and don't have a controller, like a lot of karaoke djs.
You're original question seemed like it was turned on for one deck but not the other. How would you like it to work? Make sure you explain clearly what you want to happen.
geposted Thu 07 Nov 13 @ 5:25 pm
well, i guess ill have to make a logical condition to disable it
geposted Thu 07 Nov 13 @ 5:59 pm
