Hello,
is it possible to change the behavior of sidelist so that there is no auto add for songs that get unloaded etc? I want to use sidelist solely for song reguests. So only manual drag n drop. Could not find anything from the settings.
Thanks!
Thanks!
geposted Sat 02 Nov 13 @ 5:39 am
under config/options
geposted Sat 02 Nov 13 @ 8:32 am
Config/Options/Autosave Unplayed/Disable
I prefer to use the playlist for requests, then, if I need to leave the booth for any reason, I just engage auto play. It also tots up the total play time of the list. ;-)
geposted Mon 04 Nov 13 @ 3:11 pm
