Hi there
Now, I'm looking for a Flanger effect.
Flanger standard, but has been automatically up-down,
What I'm asking is, is a plug-in that can be up and down manually using the knob.
Like KaossPad, one that can be operated intuitively to fit the groove is want.
Please let me know if there is any information.
Thank you
Thank you
geposted Sat 02 Nov 13 @ 1:37 pm
Try Flanjet or HQ Flanger on of them has it
geposted Sat 02 Nov 13 @ 2:07 pm
Thank you for your reply.
However, it was not the way of the effect I'm looking for.
From 58 seconds of this video, the effect of the Flanger have come to the movement of the finger.
http://www.youtube.com/watch?v=tSsZ_bA3IE4
I want to achieve by using a knob, the same thing.
Example…Sound is lowered by turning the knob to the left, sound becomes higher if I turn to the right.
geposted Sat 02 Nov 13 @ 4:49 pm
A manual flanger is called a 'phaser'. Not sure if there is a plugin for it, but that's the right name at least. Hope that helps a little bit. :-)
geposted Sat 02 Nov 13 @ 6:10 pm
Thank you.
How to call the difference is I did not know.
I try to check again.
geposted Sat 02 Nov 13 @ 6:28 pm
