Topic: denon 600 mapping
i am wanting to map out my denon dn 6000, does anyone know the code to
move volume slider from deck 2 to 3
move the high mid and low knobs from deck 2 to 3
geposted Sun 03 Nov 13 @ 12:13 pm
VirtualDJ Pro only: If you wish to change the order of the software MIDI mixer channels (PC MIX mode only) to 3 -> 1 -> 2 -> 4 instead of 1 -> 2 -> 3 -> 4 :
Go to CONFIG -> Mappers and choose the Denon DN-MC6000 in the drop-down list.
Find the mapping for VOLUME
Change the mapping Action: to the following:
action_deck 1 ? deck 3 volume_slider : action_deck 2 ? deck 1 volume_slider : action_deck 3 ? deck 2 volume_slider : deck 4 volume_slider
Repeat the above for the following other items, replacing each occurrence of volume_slider with the appropriate verb as indicated below:
PFL: pfl
EQ_LOW: eq_low
EQ_MID: eq_mid
EQ_HIGH: eq_high
GAIN: gain_slider
Can be found here: https://virtualdj.com/wiki/DN-MC6000.html
thank you works like a charm
trying to find the command for the channle cue...is it pfl ? im not sure
I think plf has to do with the up faders. Cue should work automatically with that mapping. I had some issues with that deck and the cue setup also. Might be a sound card setting. What happens when you have all four decks playing and you hit the headphone cue button?
PFL = Pre Fader Level is the mapping that sends cue.
this is what i did and works great
action_deck 1 ? deck 1 eq_low : action_deck 2 ? deck 3 eq_low : action_deck 3 ? deck 2 eq_low : deck 4 eq_low
action_deck 1 ? deck 1 eq_mid : action_deck 2 ? deck 3 eq_mid : action_deck 3 ? deck 2 eq_mid : deck 4 eq_mid
action_deck 1 ? deck 1 eq_high : action_deck 2 ? deck 3 eq_high : action_deck 3 ? deck 2 eq_high : deck 4 eq_high
action_deck 1 ? deck 1 gain_slider : action_deck 2 ? deck 3 gain_slider : action_deck 3 ? deck 2 gain_slider : deck 4 gain_slider
action_deck 1 ? deck 1 pfl : action_deck 2 ? deck 3 pfl : action_deck 3 ? deck 2 pfl : deck 4 pfl
now deck 1 and 3 is on the left 2 and 4 on the right this way it maches the skin
