Any chance the devs can look into the samples playing at 100% volume each time they are played on a deck change. Play 100%, play em once while on deck one, then after once volume adjusts properly, goto 2nd deck and back, all volumes reset to 100%.
geposted Thu 14 Nov 13 @ 8:25 am
been asked a few times, not real answer on how to stop this from ruining a good set of speakers :)
geposted Thu 14 Nov 13 @ 4:43 pm
Are you using samples you imported or vdj samples or other downloaded ones? I make my samples and don't have any problems unless I use downloaded samples. The downloaded ones don't reset but the initial volumes is way too loud. To fix that I edit them with the software I use to make samples.
geposted Thu 14 Nov 13 @ 7:26 pm
ok so you edit the volume level. I'll do that today. I have just been trying to use the original crappy samples from vdj ;) but they literally SCREAM 100% volume when activated.
geposted Fri 15 Nov 13 @ 12:41 pm
Can you provide more detail?
What skin are you using? Does it happen on all skins or just one?
Which mapping are you using?
Are you playing the samples using the SX pads? Which ones - left, right, both?
What do you mean by "go to 2nd deck and back"?
geposted Fri 15 Nov 13 @ 12:53 pm
