Anybody can see what is wrong here.
Elapsed time is not working
Remain time works perfect
Even if I replace Pspent into Pleft, time doesn\'t change either, while the remain part is working fine.
geposted Thu 14 Nov 13 @ 4:35 pm
There is nothing wrong with the above code.
Most likely the textzones that dont work, are in the same area in yoru screen with another songpos element.
If another songpos element (even if its in another panel) are in the same are with textzones, then they dont get refreshed
Just make sure, songpos elements are displayed always in the same position, or not having textzones in those areas.
geposted Thu 14 Nov 13 @ 8:27 pm
Djdad,
Thanks for the tip, indeed this was the problem.
Now it's working fine.
J.
PS: This week I send you a PM with another problem I had on the graphics part. (Touch skin modifications with video panel)
Don't look any further, I also found my mistakes.
J.
geposted Fri 15 Nov 13 @ 3:02 am
You send me an E-Mail... I will show your script.... Please send me your newest xml and bmp off my skin..
And thanks for ask to change my graphics and Skin... Hahaha :D
I will help you to add the video pannel.
Best regards
Best regards
geposted Wed 20 Nov 13 @ 12:40 am
