VDJ community please help me fast!! I have a gig coming up and I NEED to figure out what is happening to my controller!! :(
So I have a full purchased version of Virtual DJ 7.4 Pro and I have been using it with my Pioneer DDJ SX flawlessly. However last night I connected a Reloop mixer to my Mac to play around with it and it didn't work because the volume/play buttons were acting weird. I thought nothing of it, but when I connected my Mac back to my DDJ, deck 2 and 4 now are malfunctioning! The play button still plays the track, but the volume slider and crossfader do too…. if a track is loaded on deck B and the volume is at 0, as soon as i raise the volume, the track starts. Once I kill it, the track stops. Same happens with deck 4, and with the crossfader. I have reinstalled VDJ and the firmware on my DDJ SX and downloaded a new DDJ SX mapping from this website. I have also tried to manually map it myself but with no luck. The controller still works perfectly with Serato though…
Can someone please help me?
geposted Sun 17 Nov 13 @ 6:44 pm
Was your SX still connected when you connected the Reloop unit?
geposted Sun 17 Nov 13 @ 6:49 pm
No it was not. When I connected the Reloop like I said, the deck's play buttons were acting weird. I did try to map the reloop out myself (During which, Virtual DJ detected that I was using the Reloop from the mapping page on settings so I am sure I edited the Reloop's mapping, not the DDJ SX)
geposted Sun 17 Nov 13 @ 6:53 pm
Now the play/pause button does not even work on decks 2 and 4… Does anyone know what is going on??
geposted Sun 17 Nov 13 @ 6:58 pm
It seems that Fader Start is enabled on the decks.
First make sure you are running the default mappers and the latest version 7.4.1 (which has a fix for the DDJ-SX when using a 2 decks skin). This means you need to delete any DDJ-SX files from Mappers and Devices folder.
To disable the Fader Start, assign a keyboard shortcut as .. deck 1 fader_start off & deck 2 fader_start off & deck 3 fader_start off & deck 4 fader_start off
Press this button on your keyboard to disable Fader Start function from the decks.
Which Reloop mixer did you use ?
geposted Mon 18 Nov 13 @ 12:37 am
