I have finally sorted and successfully installed virtual dj and my n4 controller is working all most. I have the 4 decks on my laptop and all sliders are working on the controller so far so good :)
I can't get the "cue" buttons to actually work? I plug the headphones in, press the channel I want to cue but nothing, unless I take the slider up for the chosen channel and then it plays it in the headphones and through the master, which is if no use!
I'm sure you've been asked how to solve this problem loads of times but I can't find the answer I need.
Help greatly received
geposted Tue 19 Nov 13 @ 11:19 am
geposted Tue 19 Nov 13 @ 11:31 am
Thanks for the link, I drop down the box and select headphone I then have the following options
-master: left channel / headphone right channel
-master: right channel / headphones left channel
That is the only two options I have
geposted Tue 19 Nov 13 @ 12:27 pm
RightClick on the Speaker icon (from bottom windows Taskbar) and choose Playback devices. Make sure the N4 is NOt the default selected device for Windows (choose your built on).
Select the N4 (speakers), and then Configure. Set to Quadrophonic mode (4speakers)
follow the Sound setup from the wiki link Groovin gave u above.
geposted Wed 20 Nov 13 @ 1:48 am
Cheers guys, all sorted
geposted Wed 20 Nov 13 @ 5:51 am
djdad, it would be useful to have that additional info added to the N4 wiki page.
geposted Wed 20 Nov 13 @ 3:19 pm
It is not entirely related to N4 though. This can easily happen with several devices that dont have native drivers.
It has to be a general wiki page.. will make one.
geposted Thu 21 Nov 13 @ 2:00 am
