hi every one i have to find out what bit rate the NUMARK VIRTUAL VINYL usb 2.0 interface box is is it 14bit 16 bit 24 bit,please replie or point me in the right direction as i can not find anything on bit rate with this certain mix/sound card,kind regards nz
geposted Wed 20 Nov 13 @ 10:39 am
You've asked on the Numark forum. Best to wait for a reply there.
geposted Wed 20 Nov 13 @ 10:52 am
thank you its just every site that has anything to do with this is void of any thing to do with the bit rate as i was going to use it for a stand alone sound card in my studio kind regards mark
geposted Wed 20 Nov 13 @ 11:11 am
This card was designed by Numark to operate with Numark Cue and VirtualDJ Full Pro only. There is no control panel or settings.
It just works.
If you plan to use it with other software or as a standard soundcard this is not possible.
It just works.
geposted Wed 20 Nov 13 @ 2:37 pm
