Topic: Plugin installation
Hey everyone, I'm new here to the virtual DJ forums and I have a couple questions, but first let me give you a run down on what I'm using as far as software and a controller. I'm currently running the stock VDJ LE that came with my Numark N4 controller. I'm really enjoying the software its easy to use and has a ton of bonus features that make it a great fit for me. I haven't upgraded to pro and my trial version is currently out of date. So, that being said I have a few questions... I understand that because of the virtual knob on the skin itself the producers of the software didnt add in a HPF or LPF effect in the menu. I can't deal and i've gone on the free plugins list and tried downloading a few different HPF and LPF effects that have proved themselves not effective. Heres why. I registered the software on the site and proceeded to download a bunch of different filters. I realize some of them have specific versions that they are meant for and realised that after I downloaded a few of them. I have downloaded a couple for VDJ7 and after the brief installation process I get a small menu box that says "installation successful" yet when I open my software the effect is nowhere to be found in the menu... am I doing something wrong here or what? I'm pretty good with computers and cant seem to figure this one out.. anyone else having this issue or know of a fix for this issue? any help is greatly appreciated!!!
Thanks for your time,
Mav-
geposted Wed 20 Nov 13 @ 1:47 pm
This should be posted down in the plugin section. Take a look at the sticky marked "plugin not working" the problems may also be down to the version you are using as most of the plugins I think are reserved for pro users. Check your license and see what you get for that version.
Please do not post the same message or question more than once.
You have already asked this question in the plugins forum, where you can find an answer: https://virtualdj.com/forums/182994/x/
VirtualDJ LE is limited software and doesn't support using custom plugins outside of the 20 day trial of the full VirtualDJ Pro. You can upgrade to the full VirtualDJ Pro at a discount by going to https://virtualdj.com/buy/
Please see our FAQ pages: https://virtualdj.com/wiki/How%20do%20I%20change%20the%20skin%20or%20use%20plugins%20in%20VirtualDJ%20LE%20or%20Console%20Edition.html
[Duplicate topic closed]
