Hi and sorry if this post is in the wrong thread, although i see this as a general issue :)
Im having a slight problem when beat matching, basically i have been mixing for years and learnt back in the day on a pair of Technics 1210's, the problem im having with VDJ is when beatmatching, basically im doing it manually and cueing on the first beat of the cut, but what is happening is it seems to be trying to match itself and throwing itself back a couple of beats, which yes i can recover from but its annoying that its snapping to a beat rather than the one i want to cue it from i.e. i put it in on beat one and its snapping to beat 3 meaning i have to push it forward to the first beat. Is there anyway i can change any settings to stop this from happening? Thankyou for any help in advance :)
Not to worry i solved the problem, the little padlock on the deck was enabled, turned it off and it has stopped doing it...
geposted Thu 21 Nov 13 @ 8:35 am
It helps if you read the manual! :-)
geposted Thu 21 Nov 13 @ 8:49 am
Disengage auto beatlock....why dont people just answer the question?
geposted Thu 21 Nov 13 @ 1:41 pm
1) He solved it himself
2) Give a man a fish.......
geposted Thu 21 Nov 13 @ 4:38 pm
