Are there any DJ's using the Numark NS6 with VDJ Pro? If so are you having volume issues? (Ex. while one platter is playing, you bring your next song and the volume drops.) If so, is this correctable, and how?
geposted Sat 23 Nov 13 @ 10:10 pm
Do you have the VDJ limiter turned on?
geposted Sun 24 Nov 13 @ 9:36 am
Simply reduce the EQ on the track that you are bringing in (E.g: Take the bass out initially and then gradually bring it back in while reducing the bass on the outgoing track) or bring it in with the volume slider low to reduce its volume initially, then gradually increase while decreasing the outgoing track. If you are using the crossfader, try one of the other crossfader modes in CONFIG -> Options so that the volume of the outgoing track is reduced before the crossfader reaches the half-way point.
If you play two songs simultaneously at the full volume then this will result in an increase in overall volume that may trigger the limiter (Without the limiter enabled, you would get distortion instead.)
Please see https://virtualdj.com/wiki/Limiter.html
geposted Sun 24 Nov 13 @ 1:02 pm
