Hey all! I'm looking to buy a new controller, been using the original hercules rmx for years....I don't work a ton, maybe once or twice a month in bars/clubs, so don't want to break the bank. What would you guys recommend that's under $500.
Thanks!
Thanks!
geposted Sun 24 Nov 13 @ 10:27 am
Any thoughts on the RMX 2?
geposted Sun 24 Nov 13 @ 12:14 pm
If your already familiar with the RMX and like it then shoot for the RMX2. However the NS6 is now $499.95, half what it retailed for just a few years ago. Its a solid lightweight unit and perfect for bars & clubs.
geposted Sun 24 Nov 13 @ 4:07 pm
Really? It's still £699 ($1134) in the UK.
geposted Sun 24 Nov 13 @ 4:11 pm
Yes, Guitar Center and Amazon both $499.99.
Also found a nice soft case on Amazon for $140. All you need in addition to that is the USB cable from DJ TechTools ( $15 ).
geposted Sun 24 Nov 13 @ 4:23 pm
Any big differences between the RMX and the RMX 2 other than the balanced output (which is important to me)?
geposted Sun 24 Nov 13 @ 6:53 pm
Unlike the original RMX, it has pressure sensitive jogwheels, but this isn't important if you don't scratch. It also has higher resolution 14-bit pitch sliders for more accurate manual beat matching and four pads that can be switched between loops, effects, samples and hotcues.
geposted Mon 25 Nov 13 @ 8:22 am
Does that USB cable really make that much of a difference?
geposted Mon 25 Nov 13 @ 8:57 am
I got a Reloop Terminal MIx 2 a few months ago and I am a really liking that right now. Full featured and still fits in a large backpack. Really good build quality. A tad bit more than your $500 budget, but I think its worth it.
Another one I really like, but the jog wheels are too small for my taste, is the Denon MC3000
geposted Mon 25 Nov 13 @ 9:06 am
I haven't looked back since getting a NS6, it's a beast!!! High quality soundcard with LOTS of headroom, super responsive and the hardware mixer makes setting back up a breeze without need for an external mixer. $500 for one is a steal!!
geposted Mon 25 Nov 13 @ 9:19 am
Gemini GV4, check it out
geposted Mon 25 Nov 13 @ 10:15 am
geposted Mon 25 Nov 13 @ 10:51 am
There's always the Pioneer DDJ-SR or DDJ-SB too.
geposted Mon 25 Nov 13 @ 11:53 am
Not literally but I've had issues with losing connection between pc & controller. Most recent I could break connection by moving cable at the pc input. And this is on a 1 year old laptop with tight fitting USB's. Better to have it & not need it out on a gig.
geposted Mon 25 Nov 13 @ 3:14 pm
The RMX 2, is a great little controller. I was using it in the club for over 2 years, because it fit on top of the Denon 2016 mixer perfectly. Loved the talkover control. I was also lazy, and did not want to keep taking my Denon MC6000 out of my mobile rig. However, I missed the advantages and have rigged up the booth to fit the MC 6000. I also recommend that you not just buy a controller for your skill set now, but get one that will grow with you. Save your money and get what you want, not what you can afford. You will end up getting another controller, as soon as you get better.
geposted Mon 25 Nov 13 @ 4:22 pm
