Hi all,
I need help for connecting my my VDJ to external mixer with NI AUDIO 2, and how to do the configuration.
Thanks.
Thanks.
geposted Sun 24 Nov 13 @ 6:03 pm
You will need to purchase VirtualDJ Basic or the full VirtualDJ Professional to be able to do this. Other versions do not support separate deck outputs to an external mixer.
The sound card configuration should be:
Inputs: None
Outputs: External Mixer
Sound card: ASIO -> Choose the Audio 2 in the list
Connect appropriate cables from each output of the Audio 2 to two channels of your external mixer.
Inputs: None
geposted Mon 25 Nov 13 @ 8:11 am
Yes I have the VDJ PRO.
so after I select Asio Audio 2 is that all?
Is it right to keep DECK A CH1&2 and DECK B CH3&4?
I have one more question if you can help me out with it.
Is it possible to use 2 midi controllers at the same time (hercules & akai lpd)?
geposted Mon 25 Nov 13 @ 6:20 pm
In that case, please register your Pro serial number to your account and then download the latest version from the Download Center.
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it (Especially if you are working DJ and are making money as a result of using it at your gigs.)
If you wish to use it with an external audio DJ mixer, then yes, the above is all you need. If you wish to run it directly to PA speakers, then choose Outputs: Headphones instead (Using the software mixer in VirtualDJ) and then connect the first output to your PA speakers and plug your headphones into the second output.
Multiple MIDI controllers can be used at the same time. If the controller is not natively supported then you may need to map it yourself manually or download a user-made mapper for it if available.
geposted Tue 26 Nov 13 @ 7:11 am
