Hi,
I've just started using content unlimited and I'm having some problems with Track Info/Stream Id...
If I look in the history folder to see what I found from a previous session many of the tracks only appear as their Stream ID which isn't very informative!
The full details are available if I look in the Tracklist.txt file, but if I search for those tracks the listing under the contentunlimited search results come up as their stream id.
What is going on and is there any way to do a reset so that all tracks come up with their full info with ContentUnllimited?
Cheers
Cheers
geposted Mon 25 Nov 13 @ 9:27 am
Please see https://virtualdj.com/wiki/I%20am%20unable%20to%20save%20ContentUnlimited%20songs%20in%20a%20playlist.html
History files are just playlists, so if you have streamed a ContentUnlimited file directly from the Internet instead of first caching it and then loading the cached version, the above will apply.
geposted Mon 25 Nov 13 @ 9:44 am
Many thanks for the quick response.
I had found that page but your explanation makes sense of the entries in the history files.
The problem of the Stream Id coming up in the search results seems to be solved by closing down virtual dj and restarting it. Not sure why this should be
Final couple of questions:
1) Is there a way of finding out what searches have been made in the past ( a search history file?)
2) Search results for the same search query seem to be inconsistent and different on different occasions - is this normal and is there a reason for this?
Cheers
Cheers
geposted Mon 25 Nov 13 @ 10:48 am
