I would like to know how to put vdj on Automix for a playlist but not have it beat match. The reason is it slows down for songs or speeds them up as well.
I would just like the songs to cut in and play at there regular speed.
I went to settings but could not find it.
Thanks in advance
Thanks in advance
geposted Wed 04 Dec 13 @ 3:23 am
In playlist make sure you select one of the fades in automix type and select your preferred automix length. I have mine set to fade (remove silence).
You may have mix tempo and allow selected in the bpm values. I have mine set to mix fade.
geposted Wed 04 Dec 13 @ 7:03 am
Will do
Thank you very much!!!!
geposted Wed 04 Dec 13 @ 9:30 am
