Hey , i use VDJ pro with a DDJSX controller now and all is great except i'm getting slight visual stuttering on the discs (on screen) and the leds on the jog wheels , the sound and video output to secondary screens is running like silk though , is there any way i can tweak the video settings in my laptop or vdj to correct this , i use a sony vaio core i5 with 4 gb ram with nvidia dedicated graphics running windows 7 , i experience no visual stuttering when using my denon mc3000
geposted Fri 06 Dec 13 @ 8:03 am
Are you sure VDJ is really using your dedicated video card?
Are you able to select it in the video options in VDJ?
geposted Fri 06 Dec 13 @ 1:16 pm
VDJ is using my Nvidia Graphics card , Yes , worked with the controller last night in a walkabout bar on a 4 hour set and there was no issues with sound or video quality though the venues pa and 18 plasma screens , the stuttering is visual on the controller and on the vdj skin only , cpu meter shows about 1-3 bars while playing a mp4 file which is slightly hotter than when my denon is connected. The cpu will jump to almost half way when a file is loading ( which it always has done ).
Very keen to find a fix for this asap as my experience with the unit so far visually is not as it should be.
Firmware and drivers are all up to date too :-(
geposted Sat 07 Dec 13 @ 10:11 am
try using the hd swap skin, or changing skins. I use the swap hd skin and it rocks
geposted Sat 07 Dec 13 @ 2:05 pm
Is the stuttering constant, when you load a track, goes to the beat, or just random?
geposted Sun 08 Dec 13 @ 12:34 pm
how much ram on the Nvidia ??
also there are very helpful tweaks and optimizations for your laptop in the wikipedia , some or all of those
might help
what's a walkabout bar ?
might help
geposted Mon 09 Dec 13 @ 7:08 am
It's a chain of bars in the UK !
geposted Mon 09 Dec 13 @ 8:12 am
I do Video dances all time , can you do me a favour and open a mp4 and play it , Now open View task Manager , then click process , look for the Virtual DJ , and tell me what KB its running at when playing the video
geposted Mon 09 Dec 13 @ 9:50 am
have you tried playing a sample and gotten it to pay for you... at 100% volume.... ya, be real careful playing samples, they instantly play at 100% volume.
geposted Mon 09 Dec 13 @ 12:01 pm
