HI, i really need to know what cable should i get to hook up from my dj controller to any pa speaker. please help. also what cheap and good pa speakers should i get
Thanks
Thanks
geposted Wed 11 Dec 13 @ 8:59 pm
The cable you need depends on the speakers you buy!
There are powered speakers and there are passive speakers. Different makes/models have different connectivity.
Decide on your speakers first, then buy the cables.
Cheap and good? In most cases, speakers will either be cheap or good - not both. You want quality? It costs money!
geposted Thu 12 Dec 13 @ 6:35 am
Tight budget, look on Craigslist for a pair of 15" powered speakers.
Otherwise shop online for a pair of 15" powered within your price range. I believe your output is RCA, so you will need a pair of RCA to XLR cables.
geposted Thu 12 Dec 13 @ 3:42 pm
How cheap is cheap for you? How much are you looking to spend? It will make it a bit easier for someone to give you some suggestions.
geposted Thu 12 Dec 13 @ 11:01 pm
