Ive had the newmark mixtrack pro for a while now and have been running it with VDJ and using a stereo. I recently bought a pair of KRK Rokit G3 speakers. How do I connect the speakers to the mixer and what configurations need to be used for them to work properly. Thankyou
    geposted Fri 13 Dec 13 @ 3:44 pm
          You could hook them up with the same RCA cables you used for the stereo, the Rockits should have a single RCA in on each.
Or you could buy adapters to use the RCAs out of the MTP into the balanced connections on the Rockits, 1/4" TRS or XLR.
The Rockits give you a few options, but for home use the RCAs should continue to serve you well.
geposted Fri 13 Dec 13 @ 4:02 pm
          But how would I be able to connect the two speakers together then into the first output on the controller? I used two separate TRS to RCA cables and plugged them each into the mixer and sound only came out of one
    geposted Fri 13 Dec 13 @ 4:16 pm
