I have a question that I hoping that someone could answer.
I am running virtual DJ 7.4 and VMS4.1 midi console.
Here is my set up... song on deck 1 playing, song on deck 2 being used to sample.
Once I sample my parts on deck 2, I hear that part being played on deck1. I cannot mute it from deck 1...
I'd like to be able to use my crossfader to bring my samples from deck 2 into the mix... but as it stands, I cannot not.
How can I tell the system to not automatically play samples from deck 2 into the deck 1 mix?
Does that make sense?? Am I explaining myself correctly?
joe...
joe...
geposted Sun 15 Dec 13 @ 3:02 pm
Ok, so I'm playing around with things, and my VDJ crashed... after it did, I rebooted my system and it looks like things are working... or maybe I'm just doing things differently this time.
So, if I use the SAMPLE volume control, it seems I can use that to help make my samples fall out of the mix...and then use a combination of the deck 2 volume (all the way up) and the crossfadrer to work my samples into the mix. Not the best solution but I can make it work. it's not that I'm sampling that much and because of that, all the little steps to get where I want will probably be forgotten... I need simple, intuitive steps...
joe...
joe...
geposted Sun 15 Dec 13 @ 3:22 pm
