Hi i was wondering if you get a hard copy of Virtual Pro 7 once you upgraded from LE (getting the discount and everything) or is it an electronic download?
geposted Sun 22 Dec 13 @ 6:36 pm
Sorry, the upgrade is electronic download only.
A boxed version is only available when purchasing the software in full and is more intended for giving as a gift.
You can easily make your own hard copy by burning the install file on a writeable CD or copying it to a memory stick.
geposted Sun 22 Dec 13 @ 6:50 pm
Electronic Download.
geposted Sun 22 Dec 13 @ 6:51 pm
That's great!!!!! thank you so much for responding so quickly i greatly appreciate it! happy holidays-Dj Lost One
geposted Sun 22 Dec 13 @ 7:01 pm
Not only is it a digital download, it's one thing you never have to worry about.
The latest versions of all your registered/purchased software will always be available from your Download Center. So there really is no need to keep a copy burnt on to disk.
The latest version is only a few clicks and a download away...
Cheers,
Roy
Cheers,
Roy
geposted Mon 23 Dec 13 @ 12:13 pm
