Hi
Although virtual DJ is really good not the clearest of instructions, does anyone know if you subscribe to karaoke plan $19.99 does this give you tv output to play your tracks. if not is there any other karaoke players for the mac that anyone rates to play cdg files simon cardiff
geposted Wed 25 Dec 13 @ 10:43 am
I'm pretty sure you need VirtualDJ Pro to send output to an external screen. Won't work on Home Free or LE versions.
Keith
Keith
geposted Wed 25 Dec 13 @ 11:08 am
Keith
Keith
Exactly!
geposted Wed 25 Dec 13 @ 11:11 am
Keith is correct, you will need the pro version for output to second monitor.
hi guys ,
i have vdj pro , how do send video on karaoke to an external source ? what cable is needed for a mac book to tv ?
geposted Thu 30 Jan 14 @ 2:13 pm
Depends on what macbook you have, but basically a hdmi cable.
Then extend your desktop to this 2nd monitor (tv) in mac OS, and choose the 2nd monitor as video out in VDJ video settings
Thats it ;)
geposted Thu 30 Jan 14 @ 2:25 pm
Some useful info and instructions are also available here.. https://virtualdj.com/wiki/How%20do%20I%20output%20video%20or%20karaoke%20to%20a%20TV%20or%20projector.html
geposted Thu 30 Jan 14 @ 7:50 pm
The graphic that Rune has shown would benefit from being on that wiki page IMO
geposted Fri 31 Jan 14 @ 6:47 pm
hi ,
I'm still trying to hook up a external tv for karaoke , i have a mini display port cable for my 2012 mac book pro but i need to connect to a non hdmi tv , i have bought a hdmi to RGB A/V component cable as i only need video displayed (karaoke lyrics ) not audio but doesn't work , no single being received .
I have read this might not be compatable to go from digital to analog . can anyone help ? or tell what cable to make this work .
thanks
thanks
geposted Wed 12 Feb 14 @ 10:23 am
nickcam wrote :
hi ,
thanks
thanks
You'll need a "PC to TV Converter Box"
there are many depending on your computer and TV connections. I use a Sabrent HDMI to A/V (composite RCA jack) to send to monitors. Karaoke is usually 800x600 or less, so don't worry about it being HD (720x480 or 1920x1080).
You'll need the box, and you'll need to remember to toggle video on from your video card in the video tab in VDJ every time you fire it up. In Windows, you can right click on the desktop and choose video properties to activate multiple monitor mode. I have no experience with Mac.
geposted Wed 12 Feb 14 @ 6:42 pm
Wait, first you say you have a display port cable, but then you say you have a HDMI to component (RGB) cable. Does your display port cable have a HDMI connection, on the other end? If you have a HDMI port on your machine, I do not see why the HDMI to RGB cable won't work. I come directly out of my HDMI port to the TV. If he was coming out of a VGA port, then he would need a PC to TV converter. I don't use a MAC, so do not know to configure the second monitor out.
geposted Wed 12 Feb 14 @ 8:12 pm
Thats it ;)
Thats it ;)
can you tell why i can't choose a 2nd monitor as video in VDJ pro ? the only option is (window) . how do i active the dual display ? I'm using a mac book pro 2012.
geposted Thu 13 Feb 14 @ 3:58 pm
I don't use a MAC, but you need to have a dual output video card. What video card do you have? If you are able to attach another video cable, it must have a dual output.
geposted Thu 13 Feb 14 @ 11:10 pm
