I have ns7ii i love the feature looproll filter effect. I would like to map a button on my
Denon mc6000 to have this effect that will be seesome does any one or djdad knows mapping
Thank you for response and help in advance
geposted Thu 26 Dec 13 @ 8:25 am
do you mean just using a button? or using a knob and a button to turn it on/enable a shift?
geposted Thu 26 Dec 13 @ 8:38 am
Button to turn looproll effect on filter knobs
Denon mc6000 already has filter knobs i want effect on the i only use 2 deck only
geposted Thu 26 Dec 13 @ 10:42 am
It doesn't sound very good, I tried it with loop_roll (native), 'rollit', 'roll' & 'looproll' and sbdj's filter, when the loop gets too small the filter stops working. the only other option is using Deun Deun's Roll DJM 700 which has a filter built in to in, but it doesn't sound as nice as sbdj's one. hopefully in VDJ8..
geposted Thu 26 Dec 13 @ 5:53 pm
Thank you synthet1c
Could you show me mapping to see if what im looking for
On ns7ii whatever mapping djdad made works fine for me
On latin mix fading out of mix with looproll filter
geposted Fri 27 Dec 13 @ 7:43 am
..kinda of on the same subject, different question though? I love the looproll filter effect as well with the NS7ii but is their any way to re-map it so that it is not in auto slip mode? I want to be able to use the looproll effect then start right back in after the loop, verses later in the song?
geposted Tue 28 Jan 14 @ 4:17 pm
Replied here... https://virtualdj.com/forums/183352/Hardware_Technical_Support/Numark_NS7_II__Support.html
Please dont post the same question in multiple threads
geposted Tue 28 Jan 14 @ 5:55 pm
