Is there a way to map the crossfader to use only the crossfader to cue up songs. I tried using the crossfader for this and it loses the signal in the main mix... I would like to find out if anyone knows how to either configure it or map it.
also if the pfl button has to be pushed... For some reason, I get a volume drop...
geposted Thu 02 Jan 14 @ 12:47 pm
Not quite sure, what u need the crossfader to do actually. Controlling the Headphones Volume or the Headphones Mix (left side only the cued song and right side the Master Output) ?
[quote=RippinRich
also if the pfl button has to be pushed... For some reason, I get a volume drop...[/quote]
Most likely your Sound Setup is incorrect. Which midi controller/sound card do you use, how have you connected speakers and headphones, and what is your current Sound Setup in CONFIG ?
[quote=RippinRich
geposted Thu 02 Jan 14 @ 1:14 pm
