Everytime i try and startup virtual dj le it just crashes. Ive re-installed several times and nothing. Any help is appreciated.
geposted Thu 02 Jan 14 @ 6:10 pm
Which controller are you using and what are your computer specs?
geposted Thu 02 Jan 14 @ 7:57 pm
I am using a Pioneer DDJ WeGo. My specs are more than sufficient. 8Gb Ram, 1Tb HDD, AMD Radeon 6700, basically a gaming PC. Every time i open up LE it just crashes but when i open up Home Free it works fine. Only downside Home Free only lets you use controllers for a few mins :(
geposted Thu 02 Jan 14 @ 8:19 pm
Uninstall both versions of the software, and reinstall the LE version. If there were drivers, I would uninstall them also. Your LE version may want you to install, before connecting controller, please follow the instructions. Update all drivers from Pioneer.
geposted Thu 02 Jan 14 @ 8:34 pm
Ok so here is where were at. I followed everything you said and it still crashes. I tried installing the software on my friends laptop and what do you know it works. Now i just need it to work on my PC. Im reallly confused on why it dosnt work still. My PC is running Windows 7 and my friends laptop runs 8.
geposted Thu 02 Jan 14 @ 8:46 pm
I also see that it gets to the point where it says "Initializing sound engine" then it crashes. I also get this error "Runtime error 216 at 0C0B54DA"
geposted Thu 02 Jan 14 @ 8:58 pm
Please put in a ticket here.
geposted Thu 02 Jan 14 @ 9:45 pm
I already have hours ago. Thanks!
geposted Thu 02 Jan 14 @ 9:55 pm
It may take a little while, but they will help you. Good luck
geposted Thu 02 Jan 14 @ 10:06 pm
