Hi All
Started playing out again but have a problem with my Pioneer Ergo and it also happened on my previous RMX.
When I make a slight adjustment on the pitch VDJ doesn't recognise it. However if I make a long up and down slide with the pitch it eventually picks it up?
What can cause this? Is there a fix?
geposted Tue 07 Jan 14 @ 5:53 am
its called "soft takeover" it prevents large shifts in the pitch if you change decks between 1 & 3 or 2 & 4. to stop it from happening change the mapping for the pitch sliders from "pitch_slider" to "pitch"
geposted Tue 07 Jan 14 @ 6:17 am
geposted Tue 07 Jan 14 @ 6:33 am
