I bought a 4mx used and just returned it today because the crossfader was broken.
I purchased a Pioneer DDJ-SR today to replace it, I had read it would work with Virtual DJ but I see I need the mapper/drivers for it. I need to purchase VDJ Pro to do this and I don't want to drop $300 not have all the features on my SR not work.
Can I get any reassurance before I pull the trigger?
Thanks,
Zach
Thanks,
Zach
geposted Thu 16 Jan 14 @ 4:59 pm
you can upgrade at a discount as you have registered the serial for the 4mix it will either be 33% or 50% off.
The DDJ-SR prabably isn't built into VDJ Home as it's only recently been released so you would probably have to wait for VDJ8 before you could test with HOME
geposted Thu 16 Jan 14 @ 5:03 pm
geposted Thu 16 Jan 14 @ 5:10 pm
I wasn't logged in when I looked at the update price... thanks for the heads up!!
Will the Pro Version work all the features of my SR?
My night is starting to look a little better.
geposted Thu 16 Jan 14 @ 5:15 pm
It should be the same mapping as the DDJ-SX just with 2 decks instead of 4. The instructions about what the mapping does can be found here: https://virtualdj.com/addons/download/src/16423/Pioneer%20DDJ-SR%20VirtualDJ%20Operation%20Guide.pdf
You might need a pro account to see it though
geposted Thu 16 Jan 14 @ 5:25 pm
Yea, I can't view it.
geposted Thu 16 Jan 14 @ 5:34 pm
Even though the DDJ-SR is not a natively supported device (mapper is not included in the latest version as it was supported a bit later), the available mapper is still an official one, so definitely it will work with VirtualDJ Pro Full.
The only issue, is that the PAD PLUS mode of the unit (watch some videos from Pioneer on Youtube to see what this offers) cant be used properly, as its sort of a "locked" to Serato SJ software.
Other than that, no issues have been reported from the 500 users who have downloaded the mapper so far.
geposted Thu 16 Jan 14 @ 7:27 pm
ive been using a Behringer DDM4000, and the wife just got me a Pioneer DDJ SR as a surprise, im used to using 4 decks skin, is the deck select 1,3 & 2,4 mapped in aswell ? and are there any skins with the 2 jog wheels but 4 channel ?
thanks :o)
thanks :o)
geposted Sat 03 May 14 @ 10:13 pm
Unfortunately, only registered Pro Users, are allowed to get the free SR mapper. Please register your license, to have access to all mappers and all skins.
geposted Sun 04 May 14 @ 12:19 am
