I normally ask too many questions and ramble, not this time.
Can VDJ take serial input from a com port?
geposted Thu 16 Jan 14 @ 5:52 pm
We support the DAC-2 which is a serial device, but the adding of new serial devices is not documented and is probably not actually do-able.
If you wanted to use a serial device you would be better off coding a a plugin in C++ to handle the I/O and decode the communications.
geposted Fri 17 Jan 14 @ 8:32 am
