This morning I turned on my system for a practice set, and I noticed a static noise coming out of my headphones through my mixer. I'm using the Behringer DJX900, and I had experienced this static noise in the past but only when using my laptop and running virtual DJ. This morning, I had nothing but my mixer and my two CDJ's hooked up to it, and that's when I noticed the static noise.
Any ideas as to what might be causing such static noise?
Again, I only have my two Gemini CDJ700 units and the mixer, Behringer DJX900, hooked up. I also switched headphones to see if it was maybe my cans, but nop.
geposted Sat 18 Jan 14 @ 5:20 pm
...and when I'm not running my computer?
geposted Tue 21 Jan 14 @ 9:35 am
And when you think you have found the problem unit...try reversing the plug (reverse polarity) while everything its plugged they way you will use it...ran into something like this as I added yet one ome guitar pedal to my 10+ pedal system..all running on power supplies.
geposted Tue 21 Jan 14 @ 4:37 pm
