Hi,
I would like to know if I could use all the possibilities thet VDJ offers with Dell venue 11 Pro tablet?
With the docking station, it offers 2 external monitors via DP/HDMI, but both can be used only with the core CPU models.
I wonder if I could use any of these to get at least 1 projector with a decent controller without CPU overload?
The Atom z3770 SoC could do the task either?, or beter go for the core CPU? (they are Y rated, so way under even the U rated ultabook models. About 5 watts maximum power)
Any advise hepls.
Any advise hepls.
geposted Mon 20 Jan 14 @ 4:59 pm
If it has an internal video card you should be okay to run a single external monitor or projector in 720p. I used to use an Asus 1215n dual core atom with 512mb n-nivea and 4gb DDR3 RAM. with all the unessential services turned off it ran video with timecodes although the cpu was pretty high and some video effects in combination froze the interface. Atoms haven't come a long way last I checked so you would probably get about the same performance. It's fun to mess around but I wouldn't recommend running a show on it.
A good batch script to disable everything you don't need made by smitten can be found an the djtechtools blog
http://www.djtechtools.com/2011/08/14/optimizing-windows-for-djing-part-i-power-script/
geposted Mon 20 Jan 14 @ 6:14 pm
