ok guys back up hd named g drive.
put copy of xml file on hd replaced all c to g but vdj still giving a new xml file.
why is this happening and why cant i use xml file i made g as all info i there
geposted Tue 21 Jan 14 @ 4:56 pm
Did you name it correctly? The external database has a different name.
Internal = VirtualDJ Database v6.xml
External = VirtualDJ Local Database v6.xml
geposted Tue 21 Jan 14 @ 5:12 pm
cheers mate ill try that later.
can i just rename the xml file
geposted Wed 22 Jan 14 @ 1:47 am
The internal DB has a absolute file location for entries, e.g C:/YourPCName/Users/Music/Whatever.mp3
as where an external DB has a relative location eg RootOfThisDrive/Music/Whatever.mp3
I honestly am unsure if your set up would work, I don't think it would, but it might.
geposted Wed 22 Jan 14 @ 3:11 am
Why not copy your files through Vdj and you will have all copied, with a new database, cuepoints etc....
geposted Wed 22 Jan 14 @ 9:51 am
ok just updated on file info and renaming xml and seemed to work guys
geposted Wed 22 Jan 14 @ 10:20 am
