Yesterday I updated to 7.4.1 and everything seemed ok. I didnt get a chance to test it out other than to open it and make sure Vdj started properly. Normally I will try an update for an hour or so to make sure I have no issues. I called called last minute last night to fill in for a friend, grabbed my laptop and my smaller Hercules MK4 controller and off I went. When I started Vdj withe the controller plugged in (Hercules MK4) none of my controls would work. I restarted still the same issue. When I manually loaded a song into deck 1 it loaded it into deck 1 & 3 if I loaded into deck 2 it loaded into decks 2 & 4. I ended up not using Vdj last night had to use one of the other DJ programs......
Today I removed Vdj reinstalled 7.4.1 the same issue. I went back to 7.4 and the problem is solved.
I upgraded to 7.4.1 to try out the mixtrack edge which 7.4 didnt map
Anyone else have issues with 7.4.1? I think its isolated to he MK4 as the mixtrack edge worked properly
John
John
geposted Fri 24 Jan 14 @ 9:38 am
I found the update fix in the download section Now none of my custom mappings works. I saved a copy of my mappings copied it to the mapping folder yet it doesn't work any suggestions???
geposted Fri 24 Jan 14 @ 9:48 am
I removed Vdj from my computer removed it from the registry reinstalled 7.4.1 applied the update fix then added my mappings back in. Now its all working properly, the only thing I can think of is somehow the registry got corrupted.
geposted Fri 24 Jan 14 @ 2:19 pm
I had the same problem. 7.4 works fine. What is Updated Fix Mapper file?
geposted Sun 26 Jan 14 @ 3:51 am
