I think this has been asked before but can I take the BPM info with me when I switch computers and use the same hard drive?
geposted Fri 24 Jan 14 @ 3:07 pm
Use the same hard drive?
So are you currently using an external drive, or are you wanting to take your internal one and put it into a whole new machine?
Please see this link
geposted Fri 24 Jan 14 @ 3:22 pm
I have used the DBManager to copy the BPM info from the VDJ database to the MP3 tag.
Hopefully this option will be in VDJ 8
geposted Mon 27 Jan 14 @ 11:50 am
No need to do anything if you are using same harddrive at new pc
geposted Wed 29 Jan 14 @ 12:41 pm
you should use "small tagger" instead of "db manager" to write your info to the ID3 tags also by phantomdj, he has added the ability to save cue points to the tags, and I think he was waiting for VDJ8 to update it so you can write the cues back to the database.
geposted Wed 29 Jan 14 @ 8:30 pm
