I recently buy a Dj-Tech I-Mix Controller .
I tried to use it as a midi controller for Virtual DJ but when I try to play a song it simply doesn't work .
And when I try to play a song without the controller pluged in , the song is playing .
I also have the mappers for the Dj-Tech I-Mix Controller .
The music stops just when I plug in the controller and sometimes the controller isn't recognised.
How can I solve this problem ?
geposted Sat 25 Jan 14 @ 5:17 pm
What is happening might well depend on what version of VDJ you are using and will depend on how it is set up.
If you can post information of exactly what you have, how it is connected and how you have it configured then we can make a start. The more information you can give, the better.
Daz
Daz
geposted Sat 25 Jan 14 @ 9:09 pm
This tends to happen when you have an error in your spund setup.
geposted Sun 26 Jan 14 @ 4:15 am
The MIDI implementation on the DJ Tech stuff has been a bit poor in the past. I've seen messages here before from folks who couldn't get their DJ Tech kit to communicate.
geposted Sun 26 Jan 14 @ 7:07 am
