Ok so I have a new Pioneer DDJ Wego & have installd Virtual DJ LE that came with it.
I am running this on Windows 8 64bit on a nice fast laptop with 6GB ram.
Everything works ok however...
Whenever I have a track playing, when I load another track into the other deck it makes the track playing out jump. However when I record you don't hear back in the recording. Cant work it out but obviously notvery good fr playing out in a life situation s everytimei load the next track te audience will hear the track jump????????????
Second problem I have is the layback quality of my recordings. If I record a mix without using the Wego & another external sound card it sounds mint, but recording using the wego the playback quality is not as good??????????????
geposted Tue 28 Jan 14 @ 5:56 am
Could you please check your soundcard's ASIO settings?
Set it to a higher value (e.g. 8 or 10ms) and check if the problem persists. If not, then your laptop despite being powerful enough it may need some tweaking in order to be able to handle low latency real-time audio
geposted Tue 28 Jan 14 @ 6:53 am
