hello I'm a french user
I have cdj Nexus 2000 and I would like to set the A.CUE SCRATCH function
Is someone able to do it?? If so could you help me??
Sorry for my English, I use google translation
geposted Tue 28 Jan 14 @ 6:15 am
I think this is what you mean.
jog touch
down ? touchwheel_touch on : touchwheel_touch off & goto_cue
goto_cue can specify a cue number eg goto_cue 2, or you can change the selected cue with cue_select 2 on a different button.
you could also put it behind a shift that toggles the functionality
shift button
toggle 'aCueShift'
jog touch
var 'aCueShift' ? down ? touchwheel_touch on : touchwheel_touch off & goto_cue : touchwheel_touch
hopefully that translates, sorry I can't speak french
jog touch
shift button
toggle 'aCueShift'
jog touch
geposted Tue 28 Jan 14 @ 6:48 am
Thanks a lot , i will try it after work and i will let you know if it's good
geposted Tue 28 Jan 14 @ 7:19 am
