I want to record a few vocal samples but they have an underlying beat. Are there any effects thast just keep the vocals?
Thanks
Thanks
geposted Tue 28 Jan 14 @ 12:53 pm
You're trying to record only vocals from a track that has music behind the vocal? Can't be done.
What you need is the a cappella version of the track in question. If there isn't one, then what you want is not possible.
geposted Tue 28 Jan 14 @ 1:02 pm
So there is no filtering technique, even if it warps the vocals a bit?
geposted Tue 28 Jan 14 @ 1:18 pm
If there is an instrumental version of the track which is exactly the same as the vocal one, just without the voice, then there's a technique called phase cancellation which can sometimes give reasonable results.
Plenty of info (inc videos) online via Google.
You'll never get a nice clean result with this method though. It'll always sound "swimmy", and you'll often be left with bits of music too.
geposted Tue 28 Jan 14 @ 1:27 pm
It's like mixing blue and red ink in a glas and mix them together. You could try to split them up again but this is not really possible.
Greets, Heiko
Greets, Heiko
geposted Tue 28 Jan 14 @ 1:32 pm
this might help you
greetz
rob
geposted Tue 28 Jan 14 @ 1:39 pm
