Hi
Using a Mixtrack Pro with Virtual DJ Pro and Trying to unsuccessfully remap the buttons :|
Here's what I want to do;
Out Button: pressing it creates a 8 bar loop at current point or cue point / pressing again turns loop off
Reloop Button: doubles loop length each time pressed
in button: halves loop length each time pressed
Shift button: ideas welcome
If anyone is fluent in VDJ script then I would be eternally gratefull
Reagrds
Reagrds
geposted Wed 29 Jan 14 @ 3:57 pm
Out: loop 8
Reloop: loop_double
In: loop_half
You must know however that when your 20 days trial ends all your custom mappings will revert back to the factory default.
Reloop: loop_double
In: loop_half
geposted Wed 29 Jan 14 @ 4:54 pm
Its not on the LE version. I have the IDJ 3 running VDJ LE. This is a Laptop/Controller I'm purchasing but want to make sure its all working first as when Ive tried it its using the eq kill butons as hot cues which ive successfully managed to revert back to the eq kills and the loop buttons make no sense what so ever!! Hence im trying to customise it to something more usable
geposted Wed 29 Jan 14 @ 6:08 pm
You do realise that you can't buy someone elses copy of VDJ?
If the current owner of the laptop leaves their copy of VDJ Pro on there and you use it, you're both in the wrong.
geposted Wed 29 Jan 14 @ 8:04 pm
