Is there any way to change the time VDJ uses to save the tracklist.txt file?
geposted Thu 30 Jan 14 @ 12:46 pm
From the wiki:
HistoryTimer: allows the setting of when a track gets marked/flagged as a played track.
Changing the registry entry HistoryTimer using increments in seconds controls how long a track must be played for it to be marked as played.
Default is 5 (seconds). A nominal value would be 20 or 30, so tracks played longer than 20 or 30 seconds then get marked as played and recorded to the History Play list.
geposted Thu 30 Jan 14 @ 1:10 pm
It's working. Thanks for your help!
geposted Thu 30 Jan 14 @ 3:19 pm
When I change my registry setting, then restart VDJ, my registry goes back to its original setting. Why is this, what am I doing wrong.
geposted Fri 31 Jan 14 @ 1:19 pm
did you start registry tool a admin ?
when finished, first clicked apply, then close ?
geposted Fri 31 Jan 14 @ 1:39 pm
