Hey guys I recorded a mix with Variable Bitrate but it seems like VDJ is having a problem reading it, ITunes reads it without a problem. I recorded one with Constant bitrate and its no problems. Is there anything I need to select within VDJ so that it can read Variable Bitrate files
geposted Tue 04 Feb 14 @ 8:10 am
not really as far as i know. anyway i prefer and recommend cbr, so there is not prob @ all
greetz
rob
greetz
rob
geposted Tue 04 Feb 14 @ 8:25 am
Solution = don't use VBR.
geposted Tue 04 Feb 14 @ 8:38 am
That's what I figured thanks guys
geposted Tue 04 Feb 14 @ 9:15 am
VirtualDJ can normally load and play VBR files without any problem. However, because the correct length of the song is not known until the file has been loaded and analysed in full, this can sometimes cause it to be streamed direct from disk due to it appearing to be over the 'max load' length setting. So only a small part of the song waveform will be initially shown, but this updates as the song playback progresses.
To avoid this, simply analyse the file first. Please see https://virtualdj.com/wiki/MaxLoad.html
geposted Tue 04 Feb 14 @ 11:00 am
Ok thanks
geposted Tue 04 Feb 14 @ 4:20 pm
