Topic: VDJ closes randomly
It's not so much that it's random, but it happens more when I'm scrolling through effects at a faster pace. I think it doesn't happen that much AFTER scrolling, when I select said effects.
What could be causing this? It's annoying because I'm recording a set and it just shuts down, no error message, nothing (and it records up until the point I reached in the set). It's a Mixtrack Pro, btw. Are there any connections between VDJ and Gamebooster? I use Gamebooster to have my memory focus mainly on VDJ.
Thanks.
geposted Tue 04 Feb 14 @ 11:14 pm
Sounds like a problem with a non workin effect but as you are using the LE version this can not be the issue i fear.
Greets, Heiko
That's the thing, they all work just fine, but it does seem like it happens when I scroll past a specific area. I don't have that many effects, about as many as a CDJ has, but it's usually around the place on the list where I have the Noisebell effect, a reverb, etc. Dunno.
Hmmmm,
can't remember that Noisebell is a standard defaut effect.
Which version do you use exactely ? Can't be LE i think.
Greets, Heiko
how long are your recordings??? 1hr 2hrs
i mite be able to help
Had that same problem in earlier versions of VDJ Pro.
But not with the current one. Don't remember the exact version, but I think it was a 6.x were this happend.
Usually they're an hour long, but I've been able to record 2+ hour sets in the past without a hitch.
Hard to say, zero such thing here...
But you touch on some things you think yourself might be the cause.. .
Try turn off that gamebooster memory management .. Did that remove the problem?
Try scroll slower in the FX section - no more crashes?
This would be the best way to try pin point whats causing it on your pc. .. a bad/corrupted FX, 3rd party memory hack, etc.
