Hey Everyone, been around VDJ for years. Recently I have decided to try and mess with Video Recording through a webcam using VDJ. I am running the VDJ on a laptop with Windows 7. Also, using a Logitech c525 webcam. I have figured out how to activate it and am able to record video. What I would like to try and do is also record the audio coming through the webcam as well, for a live feel. So, basically, just having problems getting the audio to come through. Any help would greatly be appreciated.
geposted Thu 06 Feb 14 @ 2:08 pm
Ok, I figured out how to get the Mic on the webcam up and running. It was a matter of getting into the sound config and selecting the mic input. Problem I am having is, it is playing back through the system. It is recording audio and video now though, but will cause lots of feedback. How do I disable this. but still have it armed to record?
geposted Thu 06 Feb 14 @ 2:46 pm
What exactly are you doing with this setup? Are you trying to use it live at gigs?
For the mic to be recorded, it has to run through the mixer, so of course you will hear it at the output.
If you're doing this purely for recording then you could simply use headphones rather than speakers.
geposted Thu 06 Feb 14 @ 3:05 pm
