Topic: Can Virtual DJ be used for public broadcast?
Can Virtual DJ be used for public broadcast? i meant if i can use it outside such as an event...
geposted Mon 10 Feb 14 @ 11:44 am
Yes, VirtualDJ can be used for outside public broadcast if you hook it up to a suitable PA sound system. This is no different from using it in a club or bar.
However, you will need appropriate public performance license(s) to play copyrighted music in public at an outside event. When playing in a club or bar, you would normally be covered by the venue's license (Depending on the laws of your country.) Please check with the appropriate licensing authorities in your country for further information.
Please also note that VirtualDJ Home FREE is for non-commercial use only. It cannot be used at commercial events or gigs where you are being paid. You will need to purchase VirtualDJ to use it for this purpose: https://virtualdj.com/products/comparison.html
how do i get my stream from privite to public
Hello,
if you are using Shoutcast or Icecast Server - this is a server setting.
Greets, Heiko
