I bought a AKAI Proffesional LPD8 Laptop Pad Controller.4 Programs, 8Pads in each Program and 8 Dials.
I want to use this on VDJ for in house recordings.
I know how to map them but im struggling in how to choose two different play buttons
Say
PROG1 Pad 1 is used to play Desk 1
PROG1 Pad 2 is used to Play Desk 2
The problem is it wont let me do this
Help
Say
Help
geposted Sat 15 Feb 14 @ 2:57 pm
you need to specify the deck the action will work on
deck 1 play_pause
deck 2 play_paise
or
deck left play_pause
deck right play_pause
using left/right is better as you can use more than two decks if you use a skin with more than two decks.
deck 1 play_pause
deck 2 play_paise
or
geposted Sat 15 Feb 14 @ 3:27 pm
Thanks ill try this now
geposted Sat 15 Feb 14 @ 4:16 pm
