Currently using virtual dj pro on my pc. Is there is a way to add more than 1 second of start time before the song starts? Some of the songs I use begin right away and its nearly impossible to transition it when with that little time.
geposted Sun 16 Feb 14 @ 7:00 pm
why not just wait 1 sec then start it :)
anyway, spin the VIRTUAL RECORD backward and it gives you exactly 1 sec to start before the normal starting point of the song.
geposted Sun 16 Feb 14 @ 8:10 pm
Or just cue back from the start. I have a few records that start on beat 2 so I've just cued back to where beat 1 should be and set a hotcue sometimes it will start from the hot cue other times I have to pause cycle through the hotcues.
geposted Tue 18 Feb 14 @ 12:37 pm
