Since today, I'm having problems.
When i use the search function, the song appears, but it won't load. I always get the "Error on deck 1/2" message.
When I search the same song manually, it works!
Also, none of the songs in my playlists won't play, because of the same error.
when I have the same problem on virtual vinyl, i use the seach db function to load in my hard drive, that always does the trick.
Now I am using Virtual Dj Pro 7.4, and I can't find a solution.
geposted Mon 17 Feb 14 @ 5:54 am
Did you move your songs? Did you change the name of the directory?
If they are on an external drive, has the drive letter changed?
geposted Mon 17 Feb 14 @ 6:05 am
